Battery drain
Old Feb 23, 2020 | 11:58 AM
Matt Causey's Avatar
Default Battery drain
So I notice that the little light that indicates gear position will not turn off pretty sure its draining battery but idk but when I bought the truck it had a hid unit installed but they didn't work so I removed then but I'm still losing battery juice so if someone has any idea what could be goin on please let me know
Old Feb 23, 2020 | 12:44 PM
kevinkpk's Avatar
You'll need a voltmeter. Hook it to the battery, then individually pull fuse's till the voltage drop stops, that will get you to the circuit(s) that's causing the issue.
Old Feb 23, 2020 | 1:58 PM
Irish_alley's Avatar
I'm here for the party
wont really work too well with a computer
Old Apr 20, 2020 | 9:38 PM
Cpalmore's Avatar
Default Same issue
I’m fighting the same problem. Also pulled the radio battery fuse and the voltage drop seemed to stop. Not sure if the instrument cluster needs work or if maybe the ignition switch isn’t turning the light off. Perplexed. Any help would be appreciated
Old Apr 21, 2020 | 3:51 PM
you'll need an electrical schematic to trace the fault
Old Apr 21, 2020 | 7:04 PM
Gumby22's Avatar
I can look up a wiring diagram for you I just need these details to select the right options in service information:
-Year
-Engine size
-4 or 2 wheel drive
-Model and trim package
Old May 14, 2020 | 7:07 PM
Cpalmore's Avatar
Default Problem solved, sort of
Replaced the neutral safety switch and PRNDL light is now off. New problem is it idles really high in park and neutral
Old Apr 6, 2021 | 10:11 PM
longslide10's Avatar
-Year
-Engine size
-4 or 2 wheel drive
Mine is a 1998 Silverado 4x4.(K1500,SWB,SC, 350CID) I have a "radio" fuse and a "radio batt" fuse. What is the "radio batt" fuse? Bringing the battery back to full charge tonight. Hope to start serious testing tomorrow.
Thanks!
Old Apr 7, 2021 | 12:57 PM
Gumby22's Avatar
Thanks!
The radio batt fuse is a direct battery feed to the radio for memory and communication after key off. The radio fuse is an ignition feed.
Neither fuse powers anything but the radio unless the wiring has been tapped into for aftermarket accessories.
Old Apr 7, 2021 | 2:25 PM
Thanks for the information.
I've pulled both radio fuses and the drain seems to have stopped.
Now, if this thing didn't have a DIN AND A HALF radio!
Don't want to use a single DIN and fill the gaps and I'm not crazy about modifying the entire dash to squeeze in a double-Din.
the Brain
Jan 1, 2020 4:40 PM
josh1331
Nova & Chevy II
Sep 14, 2013 7:49 PM
gray gables
Sep 26, 2012 10:00 PM
tdunaway
Sep 3, 2011 4:54 PM
Tieffun
May 22, 2010 6:12 AM
