Cab mounts 93 k1500
Old Nov 28, 2022 | 4:51 PM
Dadsblue71's Avatar
Default Cab mounts 93 k1500
Needing part numbers for rear and front cab mounts for a 93 k1500 mine are shot. Called local auto parts store he said they were not available?
Old Nov 29, 2022 | 9:52 PM
Gumby22's Avatar
I wouldn’t expect most parts stores to have carried them when these trucks were new, let alone almost 30 years later.
The rubberized OEM mounts are difficult to find. If you are set on having OEM you’re probably going to have to keep hunting - unfortunately I can’t help on the part number.
You can try calling a dealer - the mounts are certainly discontinued but they should be able to give you a part number.
If you’re willing to switch to polyurethane mounts, there’s several options.
Here’s a couple of links to sources -
LMC Truck - https://www.lmctruck.com/1988-98-che...nt-bushing-set
Rock Auto - https://www.rockauto.com/en/catalog/...body+mount,673
Good luck.
jacobgw
1988 - 1998 (GMT400)
Oct 2, 2021 10:19 AM
elleonlp
Dec 15, 2019 9:52 AM
Bigfoot_Chevy_Owner
Aug 30, 2014 1:01 PM
jlemon5785
Mar 5, 2011 10:12 PM
K1500RFD274
May 29, 2007 7:46 PM
