Cab mounts 93 k1500
I wouldn’t expect most parts stores to have carried them when these trucks were new, let alone almost 30 years later.
The rubberized OEM mounts are difficult to find. If you are set on having OEM you’re probably going to have to keep hunting - unfortunately I can’t help on the part number.
You can try calling a dealer - the mounts are certainly discontinued but they should be able to give you a part number.
If you’re willing to switch to polyurethane mounts, there’s several options.
Here’s a couple of links to sources -
LMC Truck - https://www.lmctruck.com/1988-98-che...nt-bushing-set
Rock Auto - https://www.rockauto.com/en/catalog/...body+mount,673
Good luck.
Good luck.
jlemon5785
Mar 5, 2011 10:12 PM
