Can't get a solid brake pedal
Old Dec 11, 2021 | 11:03 AM
  #41
Mr. Dude with a face's Avatar
I don't believe I added this initial, but here is a link for those clips that you will need if you choose to replace the booster, my 98 uses the round clip.
Amazon Amazon
Old Jan 4, 2022 | 6:39 AM
  #42
larryt's Avatar
i had the same problem it took me two days to fix it but to my over site i put the caliper on the wrong side check it and see the driver side will have two reg bolt in it just though it might help
Old Jan 4, 2022 | 8:11 AM
  #43
Thank you for metioning. Thankfully that was not my proablem. The truck is still stoping great.
Old Jan 7, 2022 | 4:22 PM
  #44
tank1949's Avatar
Originally Posted by Gumby22
1) There’s a pintle on the combination valve that needs to remain depressed during bleeding. It meters fluid flow to the rear brakes and can allow air to be trapped inside the valve, regardless of how much time and fluid has been used.
Have a helper depress the brake pedal and look/feel for the pintle - it’s typically on the top or front of the valve, covered by a black cap. The one that extends when the pedal is pressed is the one that needs to be held down.
There’s a clip tool available for this (https://www.amazon.com/OTC-OTC7853-V...P%2CB07NV4943F), but a penny and tape or zip ties will work if you can secure them properly.
Valve/pintle location
2) A method I’ve always used for adjusting drum brakes is to tighten up the adjuster until you can’t turn the wheel, then back off the adjuster one full turn. Then go for a short test drive (2 miles or less) and check to see if the drums are too hot - if so, back the adjuster off another 1/4 turn and repeat.
I’ve used this on several different makes and years and it’s worked every time.
That may be unnecessary if owner has ABS. I am not real sure if proportion valve is needed with ABS. My 1995 didn't have one that I could easily see. My ABS gave me a fit in bleeding after I replaced MC and brake cylinders, One cylinder leaked so I replaced both. so, I removed power supply and bled at ABS connection. It seemed to have made major difference. .
Old Jan 10, 2022 | 7:11 PM
  #45
Gumby22's Avatar
Mr. Dude with a face:
I’m still at a loss for what happened when you had the truck up with the brake pedal rigged. The only thing I can SWAG (Scientific Wild *** Guess) at is rigging the brake pedal killed the brake shift solenoid, and either it cooled down enough to [kind of] work again or you ended up forcing it to break free. Re-reading my post now, I see I failed to mention anything about it so I must’ve overlooked it.
Sometime in the 60’s or 70’s, proportioning and/or metering valves became federally required on vehicles with front disc and rear drum brakes. They allow for hydraulic balancing of brake pressure and force between calipers and wheel cylinders to ensure proper control during normal and emergency braking, regardless of ABS capabilities (at least at the time these trucks were built).
Old Jan 17, 2026 | 3:02 PM
  #46
Mobbsdeep's Avatar
Originally Posted by Mr. Dude with a face
So, its the next day, and I drove the truck, and belive it or not, the pedal is FINALY nice and stiff and up at the top. I don't know if it was replaceing the booster, or if it was that yesterday, the truck was bleed for 2 straight hours to get the air out from disconecting the master. In finall, I would not bother messing with the pintle again, as it never seemed to do anything, and same story with the ABS. I would get a gallon jug of brake fluid, and a few people to help bleed, and use the entire thing. I think these trucks like to trap air and or, the boosters fail in a way that makes the pedal soft. I belive I described it in anothe post, but I will again to be thourogh, but I was told that durring yesterdays marathon bleed, sometimes, after the pedal had been pumped up and then the bleeder was cracked open. The pedal would not drop at all. Sometimes it would go all the way to the floor, sometimes only half way down. I have no good clue as to what this could be, but I am not complaining, and I am not going to mess with it, the brakes work fantastic right now! I did a few VERY hard stops, and was abble to engage the ABS multiple times tonight on dry pavement. So, in conclusion, if you have to replace the master cylander, get yourself a booster while you are at the parts store, because as you can see, the first post I made, was OVER A MONTH AGO. I look at it as cheap insurance, especially as it was not too hard to replace, just make sure to get a new clip so you dont have to wory about reusing the old one. Their are plenty of good videos on how to replace the booster, but once you get the basic idea, it becomes self explanatory. It also might be a good time to replace your brake light switch too, since you will already have it out and it can cause your cruise control to not work (I replaced mine a year or 2 ago for that reason). I would not bother trying to do an ABS bleed, or use the previously mentioned pintle depression method until you have agressivly bleed the brakes. I hope this thred helps anyone who is haveing issues, and thanks to those who where very helpful, like @Gumby22 .
Was your brake dash light on this whole time? I had 2 bad cycnliders leaking. replaced both... bleed all 4. But the sloshing in the reservoir is way to much sloshing. And the light is still on. Dont appear to be any leaks....
but I'm wondering if its the brake booster? The brakes are no where near as spongy as before. And way better. But not perfect. And the light is still on which had lead me going thru this forum...
Old Jan 17, 2026 | 3:31 PM
  #47
@Mobbsdeep Thankfully I am going off of memory here, as I have not had to touch the brakes since I last posted on this thread I started a couple years ago. I don’t remember having any lights on at all. What year, and model is your truck?
Old Jan 17, 2026 | 7:48 PM
  #48
Mobbsdeep's Avatar
92 silverado 1500 5.7 2wd
​​​​​50about a month ago I had a bad leak. Ended up being a rear brake cylinder. We put a new one in, bled. The other side was going to break or strip so we didnt try to bleed. Well after that leak was fixed. We still having very spongy brakes. So today we took off the drum cover and the other side was also leaking. Changed that one too.. after we bled all 4 brakes, to the point that all 4 squirted out fluid with force. When I hit the break, the fluid in the reservoir is VERY sloshy. Amd if lid is not tight will blow right out. Even at half full. I been told the fluid shouldn't have THAT much movement. Moreover, when going 40+ mph the i dont get tona full stop untill pedal is to the floor almost. Anything less than 35 30. Not so much. So I do have breaks. Just to much spongy. And I'm not losing fluid anymore. And the bleeding on all 4 checked out... so now I'm to the point where I dunno if its the booster and cylinder or one or the other. My mechanic friend is thinking its not a broken seal or I would be losing fluid. While my other friend is saying if the booster was failing it would feel like pushing on a brick. So thats where I'm at. Oh and the brake light on the dash is staying on
cujoe_da_man
Apr 21, 2021 6:29 AM
samsaridinc1500
May 2, 2013 9:24 PM
Silva32
Feb 7, 2013 5:49 PM
windpower79106
Jan 4, 2012 9:49 PM
VVG
Dec 15, 2006 12:30 AM
