Engine starts runs for 5 or 6 seconds then dies.
Old Jun 10, 2023 | 9:20 PM
strategy400's Avatar
Default Engine starts runs for 5 or 6 seconds then dies.
I have a 1998 Suburban K1500 5.7 vortec. Starts and runs like a dream for 5 or 6 seconds then slowly sputters out. If I touch the throttle during the 6 seconds it immediately konks out.
If I unplug the maf and map sensors it will keep running, nice and smooth, respond to throttle etc. (default maps are running it?) so I don't think it is fuel pump pressure related or security related. I already replaced the maf sensor, no difference.
Anyone?
Old Jun 12, 2023 | 8:18 AM
oilcanhenry's Avatar
Anyone?
You likely have a bad fuel pressure regulator IMO. I own a 1998' K-1500 so that would be my guess, even if you don't. Unplugging the MAP sensor won't change that, but you can change it out if you'd like to. Personally, I'd run a fuel pressure sensor on it. 55-to 62 PSI is considered normal with 60 PSI being ideal.
Old Jun 12, 2023 | 9:55 AM
Welcome from Florida. Is the check engine light on?
mrandmrsjblack
Nov 8, 2018 2:37 PM
Zad
Aug 20, 2013 9:46 PM
chon41017
Dec 5, 2011 7:26 PM
wakind
Sep 13, 2008 11:02 AM
mookie
Aug 23, 2007 3:09 PM
