jerks on starts and stopping
Old Jun 12, 2024 | 3:18 AM
Kourso's Avatar
Default jerks on starts and stopping
1994 Silverado 5.7 L V-8 Auto. 235k
My truck had the 4L60E rebuilt about 100 miles ago.
It shifted smoothly & on time.
Now something has changed, it jerks on starts & stopping. To the point of almost 0 rpm
The 1-2nd shift points have changed now & it slightly revs like 500 rpm higher on shifting into 2nd gear.
The torque converter was not replaced on the rebuild.
The trans. guy says it’s either a bad TPS or ECM (computer)
The only other strange thing is that recently with those same symptoms, the engine has been very hard to start. Cranking over & over, until I pour about 1/2 oz. gas into the throttle body.
then it finally starts, missing heavily like flooded for 5-10 secs. then idles & restarts with no problem??
So I’m thinking these problems are related.
I thought maybe it could be bad gas (water) ?
I think that is still a good possibility?
What is the best way to confirm water in the gas? And eliminate the water if found?
Maybe break the gas supply line at the fuel filter & catch some in a glass jar?
And let it settle out for awhile?
I will be replacing the TPS, MAP sensor & IAC valve today.
I have not had a problem until after I sat the truck unused for 3-5 days at a time, several times.
Do you think possibly water settled to the tank bottom and is in all of the fuel lines causing the low performance, very hard starting & jerking.
Any good way to test & confirm a bad ECM ? This truck is a 1994 but it was built right before OBD1 came out later that year.
Thank you for your help!
Old Jun 13, 2024 | 1:50 PM
Kourso's Avatar
Please let me know if the TCC fuse is in the underhood group? I see several in line fuses? Could a bad brake switch be the problem with TCC not disengaging properly? Thanks
Oliverc2004
Mar 21, 2022 6:32 PM
akreider
Sep 8, 2019 11:21 AM
Jamie Davis-Williams
Jul 24, 2019 3:33 PM
natdancal
Oct 3, 2014 9:02 AM
Silverado Steve
Feb 14, 2014 4:55 AM
