Low oil pressure at idle.
Old May 9, 2023 | 4:23 PM
  #11
Rstone's Avatar
Is this a recent change or has low pressure been happening at idle for a long time? I have owned my 88/5.7 for well over 15 years. After the oil heats up to temp and at idle, my oil pressure always zeros out, or very close to it. Every Chevy that I have ever owned has done this. Even those with just a light. At idle the light would flicker until I started up again. I never gave it a second thought
I have had the sending unit for the gauge fail all together. When that happens the needle doesn’t move at all. It doesn’t matter what weight oil I use either.
if this has been happening all along then I wouldn’t be concerned.
Old May 9, 2023 | 7:00 PM
  #12
Gumby22's Avatar
In the interest of discussion & debate, why do you think the loss of oil pressure is nothing to be concerned about?
Or are you meaning that the loss of the oil PSI gauge isn’t a concern?
Old May 9, 2023 | 8:23 PM
  #13
Star8prof's Avatar
Default 04 Chevy Silverado Loses Power
Upon starting up, after 7 miles, it loses power and won't go over 30mph. It's a 1500 5.3 V8 2 wheel drive with throttle body. About 165K miles. Two different auto shop expensive scanners gave no codes. It does not sputter like a plugged up cat converter. Also has fresh gas. If it sits for a while it runs fine for another 7 miles then does same thing. It also idles smooth. All suggestions and ideas greatly appreciated. to solve this problem. Thanks for anyone's help. Denny
Old May 9, 2023 | 9:41 PM
  #14
Gumby22's Avatar
I’d recommend you start your own thread for this issue as it’s not the same problem as the OP.
Old May 10, 2023 | 12:06 AM
  #15
Rstone's Avatar
Because what I said. In my case this condition was repeated many times. My pressure was high when the oil was cold. It stayed high when I was driving. It went down again after the oil heated up when I sat at a light or stop sign. If it was the pump you would get low or no oil pressure regardless of the rpm’s and oil temp. I would not have gotten very far if I kept driving all these vehicles with bad oil pumps. Is the engine making any noise due to a lack of oil in the top end. If the pump was broken the engine would sound like a bunch of marbles rolling around.
fnmadog
11
Jul 30, 2015 2:59 PM
privatecarp
Nov 23, 2014 7:30 AM
hammergirl08
Jul 18, 2014 4:48 PM
a-ron
Nov 11, 2011 8:13 PM
kwoods
Dec 10, 2008 11:04 PM
