No power to fuel pump
Old Dec 31, 2023 | 8:14 PM
Nathan89's Avatar
Default No power to fuel pump
89 chevy k1500
Crank no start but starts on carb clean
I have replaced fuel pump and fuel pump relay but not getting power to pump or fuel pump fuse orange wire on relay is the only one with power any help is greatly appreciated
Old Jan 3, 2024 | 8:37 PM
Gumby22's Avatar
If you still need an answer…
Remove the fuel pump relay from its connector.
Jumper the terminals between the orange and pink/black wires. Key doesn’t have to be on. Does the fuel pump run? If yes there’s an issue with the fuel pump relay control circuit(s).
mistyrachelle
Aug 17, 2014 8:15 PM
papesta
Jan 25, 2014 10:08 AM
hunter10220
May 18, 2011 8:37 PM
89silverado283
Apr 16, 2009 9:47 PM
Enstar
13
Jun 22, 2007 10:36 PM
