Transmission
Old Apr 23, 2020 | 11:57 AM
Rowdy Goodwin's Avatar
Default Transmission
What transmission would a 1994 k2500 454 5speed manual ext cab short bed have?
Old Apr 23, 2020 | 3:27 PM
Little Bear's Avatar
NV4500 most likely, don't think a NV3500 would hold up to a 454, it hardly holds up to a 350.
Old Apr 23, 2020 | 4:05 PM
Do you know where I could get a high performance one?
Old Apr 23, 2020 | 6:57 PM
Because of the gearing I'm not sure many consider it a "high performance" transmission, I'd consider it more of a heavy duty transmission. I think most go to the T-56 for performance, I'm sure someone will correct me if I'm mistaken.
Old Apr 23, 2020 | 7:12 PM
Thank you. Do you know where I can get a complete one? Do you know if I need a adapter?
Old Apr 23, 2020 | 8:36 PM
Gumby22's Avatar
What kind of performance are you hoping for? In other words, what’s your intention for the truck (heavier duty towing/hauling or drag racing)?
What you want to do with it is the primary factor in what transmission you want to use.
An adapter/the correct bell housing should be available from who you purchase the transmission from (if you buy a new or reman unit) or they should at least be able to provide you with a source and/or part numbers for what you need.
Old Apr 23, 2020 | 10:05 PM
As far as use some off-road, mud, recovery, but mostly being fast. What do you recommend?
Old Apr 24, 2020 | 12:30 AM
Gumby22's Avatar
Then the T-56 should work just fine. If you were wanting to make it more of a work horse (towing/hauling) I was going to recommend a reman stock trans from someplace like Jasper - they don’t just rebuild them but make improvements as they go. You can also custom order a transmission to fit your needs.
Old Apr 24, 2020 | 8:30 AM
Okay. Thank you for your help.
Rowdy Goodwin
1988 - 1998 (GMT400)
12
Mar 27, 2020 7:50 PM
Rowdy Goodwin
Mar 3, 2020 8:01 PM
driftendullay
Jun 22, 2014 11:25 PM
armmata
Jun 29, 2012 4:46 AM
smith87
Feb 20, 2012 2:23 PM
