Truck wont run
Old Dec 22, 2021 | 5:25 AM
devinlisle's Avatar
Default Truck wont run
Hello everyone I’ve got me a 98 chevy c1500 thats had a whole list of things replaced and it still isn’t running right . Im just about out of ideas . Ive got what seems to be an electrical issue caused by moisture . Whenever moisture or humidity come into the air it doesn’t matter what i do the truck refuses to start . Without moisture normally it runs pretty great mechanically . It has had changed , plugs , wires , cap , rotor , distributor , fuel pump , fuel filter , injectors , and injector module , starter . Ive swapped a throttle body from my 96 tahoe onto it as well as the coil pack . Like i said unless its an electrical issue im out of ideas . Someone please help !
Old Dec 22, 2021 | 8:17 AM
hanky's Avatar
Something you might try,
Take an ordinary spray bottle filled with just plain water and carefully and selectively spray one area at a time. Mist it.
Wait a minute or two for a response.
If here is anything sensitive to moisture the spray will bring it out.
Let us know what you find, thanks.
Old Dec 22, 2021 | 5:57 PM
devinlisle's Avatar
does the truck need to be running because it wont stay running right now . Itll start run really rough and then die
Old Dec 23, 2021 | 6:28 AM
Mr. Dude with a face's Avatar
My first question is have you done anything with the ecm? I believe it is on the drivers side of the truck between the battery box and the fuse box. I don’t know if their is any special procedure to replacing one, but I am wondering if it is having issues, because at this point, from what you are saying, it does not seem like it is a sensor. Maybe you could pull the one out of the good truck, and try putting it in, and see if it starts working. Before you did that, I would VERY highly recommend researching how to remove it with ought doing something to hurt it or the truck, because they are not cheap! If you can’t find anything elsewher, I would ask @Gumby22 . Good luck.
Old Dec 29, 2021 | 9:33 PM
William Kisselstein's Avatar
Starts, runs rough, dies, I would check the fuel pressure first. If the regulator is bad, good luck, it's arduous to change.
Helmethead22
1988 - 1998 (GMT400)
Sep 21, 2021 5:13 PM
justintuah
Jul 26, 2019 6:15 PM
MrJanuszewski
Mar 14, 2017 2:26 PM
usmarine0905
Oct 19, 2013 11:43 PM
Rupesy
Apr 10, 2011 9:59 PM
