Will idle with no problem but will die if i drive it uphill almost immediately
96 Chevy 1500 4x4
Voltage at fuse box is fluctuating with key on or off but voltage at battery is fine. Any ideas?
Can you give more information? Voltage fluctuations can be several things, and do the lights/dash stop when going uphill? Could be a loose connection, what has changed, new battery etc.?
When we tests the battery voltage it stays the same running or not. But when we test the fuse box voltage it is constantly changing.....jumping from 14 or so volts down to 6, then 9 then 13 then back down to 5 then 12 and so on. Haven't changed anything.
Is your ground lead from your vom on the same place when you check battery voltage to the (I assume) main feed to your fuse box?
Joshua Wayne Tweedell
February 18th, 2012 9:36 AM
killuminatii20
November 16th, 2007 7:45 AM
Silv83
September 15th, 2007 6:38 PM
