Will idle with no problem but will die if i drive it uphill almost immediately
Old Dec 15, 2020 | 4:32 PM
Carla Griffin's Avatar
Default Will idle with no problem but will die if i drive it uphill almost immediately
96 Chevy 1500 4x4
Voltage at fuse box is fluctuating with key on or off but voltage at battery is fine. Any ideas?
Old Dec 15, 2020 | 4:48 PM
kevinkpk's Avatar
Originally Posted by Carla Griffin
96 Chevy 1500 4x4
Can you give more information? Voltage fluctuations can be several things, and do the lights/dash stop when going uphill? Could be a loose connection, what has changed, new battery etc.?
Old Dec 15, 2020 | 5:16 PM
When we tests the battery voltage it stays the same running or not. But when we test the fuse box voltage it is constantly changing.....jumping from 14 or so volts down to 6, then 9 then 13 then back down to 5 then 12 and so on. Haven't changed anything.
Old Dec 15, 2020 | 5:59 PM
kevinkpk's Avatar
Is your ground lead from your vom on the same place when you check battery voltage to the (I assume) main feed to your fuse box?
Old Dec 15, 2020 | 6:39 PM
No its not
Old Dec 15, 2020 | 7:14 PM
kevinkpk's Avatar
No its not
What you post is to me is faulty vom lead. Attach the ground lead to a same ground source i.e. battery ground post, or good frame ground.
Old Dec 16, 2020 | 12:10 AM
Ok thank you. We will
Old Dec 16, 2020 | 10:36 PM
Its fixed. Thank you for your advice.... its really appreciated!
Old Dec 16, 2020 | 11:33 PM
Rednucleus's Avatar
Please post what you did to fix the problem!!
Zach Ward
Aug 11, 2020 10:31 PM
gs400ci
Oct 20, 2013 7:18 PM
Joshua Wayne Tweedell
Feb 18, 2012 9:36 AM
killuminatii20
Nov 16, 2007 7:45 AM
Silv83
Sep 15, 2007 6:38 PM
