03 Silverado 4.3
Old Jun 11, 2020 | 9:09 PM
James The Plumber's Avatar
Default 03 Silverado 4.3
I just replaced exhaust manifold gasket and now my truck is quiet but it runs worse !! I have no power when I accelerate and it doesn’t switch gears properly high Rpms then shift hard also backfiring while accelerating but in idle sounds okay the scanner is giving me P0101 ,0102 , 0300 . Changed the plugs and wires also changed the mass airflow sensor and that did nothing !! I’m very aggravated and could use some help
Old Jun 11, 2020 | 10:19 PM
runs worse...means what. describe symptoms that describe what is happening..ie no power, misfires
Old Jun 12, 2020 | 1:16 AM
Sorry for not being more in depth . I edit my post hope this will help
Old Jun 12, 2020 | 5:21 AM
Gumby22's Avatar
Sounds like a plugged catalytic converter.
Old Jun 12, 2020 | 8:59 PM
yep +1. a clogged cat can blow out the exhaust manifold gaskets. remove the pre cat 02 sensors from the exhaust pipe to bypass the cats...it will be loud but if the power returns and the misfires gone...you need new cats.
if air can't flow out, it can't flow in ...this sets the maf code.
Ewt
Oct 29, 2019 1:03 PM
JT58.Bronc66
2014 - 2018 (GMT-K2)
Nov 9, 2018 11:47 AM
kenziekay21
Oct 11, 2015 2:16 PM
jdeoi
Jul 30, 2007 9:27 AM
Zsar
Jul 11, 2007 4:24 PM
