05 Silverado 4.3 mass airflow and random misfire codes HELP PLS
Old Apr 1, 2024 | 1:16 PM
Mays's Avatar
Default 05 Silverado 4.3 mass airflow and random misfire codes HELP PLS
05 Silverado 4.3 need help pls .. have done replaced spark plugs wires cap button mass air flow sensor air filter and coil and coil pig tail . Took throttle body off and cleaned it when I took that off and cleaned it I am able to drive but still issues running choppy has trouble accelerating. Used sea foam treatment already . It was throwing both mass air flow code and random misfire but since cleaning the throttle body they come up but not together where as before they would come up together.Can anyone pls help me no issues with smoke or smells also starts as usual. Check engine light sometimes flashes
Old Apr 1, 2024 | 5:37 PM
Check for vacuum leaks.
Those engines had intake gasket issues.
Friday99
Oct 10, 2020 5:52 AM
Randy Z
Dec 20, 2015 12:35 AM
jglidewell0708
Oct 25, 2012 9:53 AM
01softail
Feb 25, 2012 7:13 PM
mbryant13
Astro
Feb 13, 2012 12:04 PM
