2005 Chevy Silverado 5.3 72000 miles.
Old Jun 8, 2023 | 12:26 PM
Lespaul1978's Avatar
Default 2005 Chevy Silverado 5.3 72000 miles.
Has. New oil pump , New oil pump seal , New oil sending unit, screen removed,
Still has low oil pressure, Lifters tap at different times,
Does not use oil or leak.
Please Gelp Me Someone.
Thanks.
Old Jun 8, 2023 | 12:29 PM
Gumby22's Avatar
Have you verified the pressure with a mechanical gauge or are you relying on the dash?
The rockers could be tapping due to a lack of oil flow to the top end but not necessarily low pressure.
Verify the oil pressure with a mechanical gauge to determine the next steps of diagnosis.
Old Jun 8, 2023 | 12:48 PM
Rednucleus's Avatar
Tell us what your pressures are cold vs hot, idle vs highway
Old Jun 8, 2023 | 1:02 PM
When it all started , it would would take longer then normal for the pressure to come up to 30l lbs , and it was make a vibration on start up , now it's not doing that but it holds 30 at idle and 36 at 2000 rpm, and it has at one or more lifters taping after you drive it a little .
Old Jun 8, 2023 | 7:37 PM
Gumby22's Avatar
The rule of thumb for oil pressure is 10 PSI per 1,000 RPM. If the pressures you’re seeing are accurate - which cannot be verified except with a mechanical gauge - there’s nothing wrong with the oil pressure being produced by the pump.
That said, the sensor port location will only tell you the oil pressure post-filter, but it doesn’t tell you how much oil/oil pressure is reaching the lifters. The sensor port tees off the oil galleys that feed the lifters, cam and crank.
It’s possible there’s a restriction in the top end causing oil starvation. The easiest way to verify is to remove the valve covers and crank the engine over without starting it for +/- 30 seconds. By then, oil should be jetting from every rocker.
Thomas Neels
May 23, 2024 7:54 PM
heypal
Jan 19, 2018 1:36 PM
Rcktfl
Mar 13, 2017 6:06 PM
REO
10
Jun 2, 2016 6:19 PM
topofthetotem
Jan 29, 2010 5:57 PM
