2006 GMC 2500HD Transmission Adapter Leak
Old May 24, 2023 | 4:43 PM
JohnDeereJoe's Avatar
Default 2006 GMC 2500HD Transmission Adapter Leak
Hello! So I have had a steady ATF leak out of of the transmission to transfer case adapter gasket and just pulled the transfer case. Truck is a 6.0 4L80E. Is there supposed to be transmission fluid in the adapter? I thought that the seals on either side would keep the fluid out but there is a tiny hole on the transmission side and not sure what that's about ( I will attach pictures).I read somewhere that the 2wd is a "wet connection" and a 4wd is a "dry connection" but that doesn't make sense to me. Might be a bit of an Idiot though who knows. Also, there was no paper gasket between the adapter and the transfer case, just RTV. My transfer case is pretty corroded and I have a feeling that might be why. Aluminum and Magnesium connection? So if there's not supposed to be fluid in there, will I be ok to put a paper gasket in and run it? Or do I need to replace the front of the case or buy a re-man transfer case? Should I replace the Transmission housing rear output seal and transfer case input seal or should those be alright? Any insight is appreciated. It's always something.
Old May 26, 2023 | 8:47 AM
i've seen them not have fluid there and have fluid there...but with the proper gasket and a good flange seating area...the ones with fluid don't leak externally.
maybe someone else has knowledge about this...may depend on what tcase you have?
spjohnson1031
Jul 18, 2017 12:13 AM
spjohnson1031
rsmythe
Mar 28, 2016 5:42 PM
knucklebust
Jul 31, 2010 10:14 PM
fleetline51
Astro
Feb 21, 2008 7:38 PM
