2004 Silverado instrument cluster
Old May 23, 2023 | 10:34 AM
Snytex1's Avatar
Default 2004 Silverado instrument cluster
My instrument cluster works sometimes and sometimes doesn't work and I'm wondering what could be the cause of this?
Old May 23, 2023 | 12:40 PM
Please read and understand our forum rules
Rule #4: Do not double post
Thank you and welcome.
Old May 23, 2023 | 1:43 PM
Snytex1's Avatar
Oops. Ok. I belong to a couple of Chevy forums and and I thought I was posting separately.
Old May 23, 2023 | 1:56 PM
Can you please elaborate on "doesn't work". You mean the WHOLE thing goes dead? No lights, no gauges, no nothing?
Have you checked your fuses? Connectors and wires at the back of the cluster?
Old May 24, 2023 | 2:17 PM
Snytex1's Avatar
I have a local shop here that I trust, been taking my vehicles there for years, in middle TN, that tested it, and determined that it needs rebuilding.
Quote is $200 to pull, rebuild, and reinstall. I think that's reasonable.
After the work is done I'll post what the cause and fix entailed, for other members to read.
I read up quite a bit on posts from people here about 2004 Silverado clusters, but being that I just had a shoulder replacement and can't really get down under the dash and do that kind of work, I decided to just let this shop do it.
Old May 25, 2023 | 5:11 PM
Snytex1's Avatar
Snytex1 , May 23rd, 2023 10:34 AM
mountainmanjoe , May 23rd, 2023 12:40 PM
Snytex1 , May 23rd, 2023 1:43 PM
mountainmanjoe , May 23rd, 2023 1:56 PM
Snytex1 , Yesterday 2:17 PM
Back to Subforum
View Next Unread
2006 GMC 2500HD Transmission Adapter Leak
Related Thread
Home / General Tech
Instrument Cluster Frozen??
Luke C , February 28th, 2019 7:11 AM
Hello all, my instrument cluster has stopped working. (Digital readout, lights, gauges, etc.) Only a strange panel of symbols. It has done this intermittently in the past when the temperature outside dips below freezing, but only for 1/2 hour or so, then everything comes back to normal.
This time, it's going on day 3, with no signs of recovering.
It's a 2004 Suburban, 4wd.
Any ideas as to the culprit?
Thanks, Luke.
tech2 , February 28th, 2019 8:31 AM
it needs a cluster. they did have extended warranty but your probably past even that....think it was 10years coverage. there is a site sponsor here that rebuilds/replaces clusters. D & d instruments….usually in the right advertisement column
Luke C , February 28th, 2019 8:49 AM
Quote:
Thanks, I'll look into that!!
Ethan Northrop , March 4th, 2019 8:39 AM
Your instrument cluster died. You can either go OEM replacement or there another website that sells them Ill have to find it
Ethan Northrop , March 4th, 2019 8:41 AM
https://www.dormanproducts.com/appli...004&origin=YMM
Heres the link to select what you want in the site
Draxarian , July 2nd, 2020 10:55 AM
You don't need a cluster. There are many places that can fix yours. Cheaper than replacement and your don't loose mileage and VIN info. Check out the cluster repair threads. Dorman clusters are poorly made and I would fix mine vs buy one of those. BUT I guess by now you have already handled itBack to Subforum
View Next Unread
2020 Silverado 4.3 coolant leak
1/1
© 2023 MH Sub I, LLC dba Internet Brands
Old May 25, 2023 | 5:14 PM
Snytex1's Avatar
Default Instrument cluster
Back to Subforum
View Next Unread
Related Thread
Home / General Tech
Thanks, Luke.
You don't need a cluster. There are many places that can fix yours. Cheaper than replacement and your don't loose mileage and VIN info. Check out the cluster repair threads. Dorman clusters are poorly made and I would fix mine vs buy one of those. BUT I guess by now you have already handled it.Back to Subforum
View Next Unread
1/1
Old May 25, 2023 | 5:16 PM
Snytex1's Avatar
Back to Subforum
View Next Unread
Related Thread
Home / General Tech
Thanks, Luke.
View Next Unread
1/1
Old May 26, 2023 | 12:57 AM
are you having technical difficulties? why are you posting this mess over and over?
Old May 27, 2023 | 7:39 PM
Snytex1's Avatar
In all kindness dear moderator, this site, for a beginner it seems, has no way to directly respond back to responders, might it be that until one has posted a certain number of times, that this is entirely unfeasible?
Hopefully my response, though late, at least, will reach you undisturbed, and less mumpish perhaps.
