Blinker light on dash stays on even when truck is not on
Old Feb 19, 2024 | 8:32 AM
  #11
Michaelino985's Avatar
well it shouldn't kill your battery while you're driving.
its not while driving. Unfortunately when it sits for a few days it will drain battery if I don’t start it up. I’m trying for the time being to keep it from going dead. That’s why I was wondering if there’s a certain fuse I can pull for the time being to get rid of the blinker staying stuck on the dash. Stays on when trucks off 24/7. If not, until I can get it to a shop, I’ll keep it in rotation and drive it locally if need be to keep battery charged.
Old Feb 19, 2024 | 11:00 AM
  #12
frank1's Avatar
I had a similar issue some years ago, with a newer GMC 3/4 ton. The camper special wiring harness, between the cab and box, had slipped its zip tie and fell down on the hot exhaust , grounding out a circuit, letting the light come on.
Old Feb 20, 2024 | 12:39 AM
  #13
which is why I said disconnect the battery when you're not using it.
Yes, that means you have to reconnect it before going for a drive.
Old Feb 21, 2024 | 6:13 PM
  #14
my bad, true. Lol
i was spaced out. Thanks for the help. I appreciate it. I wish there was a fuse I could pull to eliminate it. Oh well
Old Feb 21, 2024 | 7:53 PM
  #15
Rednucleus's Avatar
Check your manual for fuse locations. Probably both under hood and bottom of dash by your knees. Pull anything related to lights until you find the correct one.
Old Feb 22, 2024 | 6:57 AM
  #16
ok cool. Thanks
Ohthree2500hd6.0
Jan 14, 2023 3:21 PM
KGJC616
11
Jan 28, 2019 1:14 PM
DIYguy
Sep 29, 2015 11:31 AM
rickp
Dec 6, 2014 4:43 PM
paintballhead03
May 14, 2013 9:08 PM
