A/C Problems
Old Jul 26, 2021 | 7:48 PM
Givememyneck's Avatar
Default A/C Problems
Hello I have a 2004 Silverado 4.3l. Just recently my air conditioning went out. I changed out the compressor and accumulator and still nothing. The only time it works is when I’m accelerating the truck and even like that it doesn’t blow much. I ran out of things to do to it, can someone help me diagnose this problem?
Old Jul 29, 2021 | 3:09 PM
2001 chevy silverado's Avatar
We have 0 idea what your HVAC skills are so don't know where to start.
Are you sure you vacuumed the system and filled it with the right amount of freon correctly?
Why would you change a working compressor? It's difficult costs allot. That makes no sense whatsoever.
Old Jul 29, 2021 | 4:09 PM
You didn't say if your PSI is target and free on non-condensibles, what the original diagnosis was (if there was ever a leak), or anything...
Feel the compressor line. Should be (slightly) warm at exit of condenser. Don't feel the top of the condenser, it will be too hot to touch.
Feel the evaporator return line. Should be colder than beer, say, 40-50 or less.
If they are not, then you have an AC problem. If they are - then you may have an cabin AC Controls problem.
If you have a controls issue the first thing to check is that the mixer door is not stuck (which would let in hot air and make a working AC appear to be doing nothing)
Old Jul 29, 2021 | 4:35 PM
I am not a mechanic but I do love working on cars. I am sorry for not giving y’all the proper information but the problem has been fixed. It was kind of common sense actually. As I stated before, the air coming out of the vents blew only when I was accelerating meaning everything worked except the part that pushes the air out trough the vents, which is the blower motor.
Devyn_barker
Apr 13, 2021 9:11 AM
daytooday
Jul 10, 2020 2:16 PM
texaschev
May 7, 2013 10:07 PM
komelia1
Sep 26, 2010 6:30 PM
BigCan144
Jul 24, 2010 11:49 PM
