computer gone ?
Old Apr 25, 2021 | 1:39 AM
  #21
they accept evap not complete because its temp dependant..ie it won't run in cold weather. Incomplete for the other monitors should not apply.
Old Apr 29, 2021 | 3:42 PM
  #22
Cypress123's Avatar
Also now having transmission issues, if I clear codes for the trans will that also clear the emission or internal monitors ? getting a harsh shift for all gears and a component slipping code P0849? I assume the torqconvertor.
Last edited by Cypress123; Apr 29, 2021 at 8:16 PM. Reason: to make the issue clear
Old Apr 29, 2021 | 11:20 PM
  #23
sounds like the code is causing the trans to raise line pressure to prevent the slip...hence the harsh shifts.
Old Jul 17, 2021 | 6:30 PM
  #24
Cypress123's Avatar
Default 2007 classic 4L80
On this 4L80, I just had a guy replace the torque converter it now does lockup, but the trans now does not shift above 2 when it should go to 3 or 4 it stavs in 2 - It went through all gears fine before the torque converter change, so rather sure he did some thing. no codes yet.
gafirefighter
Aug 21, 2024 4:48 PM
Billy DeVincentis
Feb 3, 2020 6:29 PM
Mike Sigmond
14
Jul 10, 2019 1:45 PM
jtown
Oct 23, 2018 6:11 PM
Javelin SST
Jul 28, 2016 8:29 AM
