Crank no start issue 2004 Silverado 5.3L “T” VIN
Old Jul 8, 2022 | 7:45 AM
  #11
thetoddfather's Avatar
Originally Posted by Girlsliketrucks
Did you check the ground strap that's located right by ur fuel pump? If it's not connected properly it will cause it not to start. I just finished installing a new pump on my 01 silverado with the 5.3 and mine wasn't connected properly after the pump got changed.
I have not. I will definitely check that this afternoon while I’m looking at everything else.
Old Jul 24, 2022 | 2:44 PM
  #12
Ok so I have found the following
-unplugged both seats and door switches. Issue remained
- hooked up fuel pressure gauge. 60 psi when starting. Does not lose psi when I turn the key off. 55+ at idle.
- any more ideas?
Old Oct 22, 2023 | 12:50 PM
  #13
Tmack729's Avatar
Was there a final solution to this issue?
Old Oct 22, 2023 | 8:37 PM
  #14
@Tmack729
that person has not visited the forum since that was posted. You should probably make a new post with full details of your truck and situation.
Old Oct 23, 2023 | 5:27 AM
  #15
Tmack729's Avatar
My truck had an identical intermittent starting issues as this one. Turned out to be the Camshaft position sensor
2004ChevyTahoe
Apr 29, 2022 6:54 PM
Mamahoney
May 30, 2021 6:02 PM
96blumina
Dec 22, 2017 7:36 PM
rcdyer1972
Feb 4, 2012 10:36 AM
sscamaro2001
Jul 5, 2008 2:52 PM
