Quick post about my 2004 Tahoe, help
Old Apr 21, 2022 | 1:06 PM
2004ChevyTahoe's Avatar
Default Quick post about my 2004 Tahoe, help
Hello all,
I haven’t driven or started my 2004 Tahoe in a few months. I just got a new battery and installed it.
When I turn the key in the ignition, all powered lights are working great. When I turn the key to start the truck, the starter cranks, but it just keeps cranking.
Before I dive in and disassemble things to find the problem, can anybody help me with where I should start? Might my problem be the starter? Maybe the fuel pump? Maybe spark plugs? Alternator?
Please offer any advice, thanks ahead of time.
Old Apr 21, 2022 | 3:00 PM
Welcome from Florida. Is the check engine light on? If it is the code will tell you a good place to start.
Old Apr 21, 2022 | 3:04 PM
Default Check engine light does not turn on
No the check engine light doesn’t turn on.
Any other suggestions?
thank you
Old Apr 22, 2022 | 8:20 AM
Cusser's Avatar
Spray some aerosol starting fluid into the air cleaner or throttle body, try to start, do this a few times. If it runs for a few seconds then quits out, you have a fuel delivery issue, start there. If it won't run at all when you do this, then it's a spark issue, work on that. This is a common first test to help isolate the problem. This is practically an ALWAYS: isolate whether spark or fuel. And remember: just because the engine can crank fine, doesn't mean that the electrical part of the ignition switch (the "run" circuit) is OK.
Old Apr 29, 2022 | 6:54 PM
DopeUnicorn's Avatar
Originally Posted by 2004ChevyTahoe
Hello all,
When you turn your key, can you hear the fuel pump engage? It makes an audible noise. If no noise, check your fuel pump relay in your fuse box under the hood
jentoe91
Mar 30, 2022 12:52 AM
Mamahoney
May 30, 2021 6:02 PM
gjo5475
Feb 20, 2015 8:50 AM
lynchcrew
Nov 17, 2012 7:34 PM
Big D
Aug 18, 2007 8:50 AM
