Engine stalled
Old May 21, 2024 | 8:09 AM
Stob's Avatar
Default Engine stalled
'02 with the 4.3 V6, 193K miles. Driving yesterday and it just died. I was able to get if off the road then towed to my house. I don't have a scan tool, but tried several methods on line. The only readout I got was using the hold the odometer rest button, turn key on, release button, and I got a read of h5311.4. I couldn't find a code like that anywhere. I looked at the method of using a jumper at the connection for a scan tool, but the image I saw showed lumping the upper right two terminals. On my truck those two slots are empty.
I texted a friend who has a scan tool, hopefully I can borrow it and find out what's going on.
Old May 21, 2024 | 10:17 AM
jfmorris's Avatar
Yeah - I think you need a scan tool for sure. Amazon has cheap ones down in the $25 price range. Personally, I use a ODBLink SX cable ($50) that connects to my Windows laptop. So far I really like the ODBLink capabilities, on the 4 vehicles I've used it with anyway.
Old May 21, 2024 | 11:57 AM
The h5311.4 is the hours on the engine. You definitely need a scan tool.
Old May 21, 2024 | 1:47 PM
Does it start?
Old May 21, 2024 | 2:41 PM
Stob's Avatar
OldChevy, awesome. Had no idea hours were tracked on an automobile. Commonplace on heavy equipment.
MMJ, no. It died while driving and I tried to restart with no luck.
I checked fuel pressure today, used an old set of refrigeration gauges, went right up to 60 pounds. I'll check for spark with an old spark plug tomorrow when I have help to turn the key. My friend with the scanner might get hear tomorrow sometime.
Old May 21, 2024 | 3:03 PM
Is it cranking?
Old May 21, 2024 | 3:19 PM
Stob's Avatar
Yes it cranks fine.
Old May 21, 2024 | 5:10 PM
did you wait 15 minutes or so to see if it's able to hold that pressure?
Have you checked all the fuses?
Old May 22, 2024 | 7:55 AM
frank1's Avatar
Cheap scanner -- https://www.harborfreight.com/automo...der-64981.html
Old May 22, 2024 | 8:31 AM
Stob's Avatar
I did not wait to see if it held pressure. I checked fuses this morning and all is good.
I will look into that scanner, I have an item from them I want to get anyway.
