Starting problem
Old Jan 16, 2022 | 1:00 PM
Jmpks70's Avatar
Default Starting problem
New battery new relays ign1 and starter relay. All accessories work. Checked all fuses and still won't crank. I can hear the fuel pump come on. I hear a single click when I turn key into on position. ????? PLEASE help if you can.
Old Jan 16, 2022 | 5:52 PM
hanky's Avatar
You might consider the following,
Turn headlights on and have someone watch them as you attempt to start the vehicle.
If the headlights go dim , could be ,,,,,,low battery, poor battery cable connection, or defective starter.
If no change, carefully ,,,tap the starter motor then try again and see what you get. (If the brushes are worn, this will work once or twice)
If still no change possible neutral safety sw, ,,problem,,,or poor connection at or to starter or starter has open circuit.
94burb
Feb 8, 2026 4:06 AM
Typerod
Jan 7, 2022 3:39 PM
Jrock1982
May 14, 2018 11:23 AM
Bpopilek
HHR
Apr 20, 2018 9:57 PM
sagags
Apr 1, 2010 4:17 PM
