2008 Silverado 4.3 work truck broken hose? Engine lights
Old Mar 4, 2024 | 8:26 AM
JoeV1973's Avatar
Default 2008 Silverado 4.3 work truck broken hose? Engine lights
My 2008 Silverado 4.3 work truck which ran smooth as can be, which is used for a hay truck & still very much needed is having a problem.
Live in very rural South Tennessee hills, no plows, no salt trucks & no snow (usually) about a month ago we got some ice & my daughter slid down the hill into the ditch & bottomed out.
After we yanked it out, engine lights came on..this truck is running like crap. When you drive it, only when you first start it which starts fine, idles down our gravel road fine, but once out on the main road it spits & pops a couple times , like a quiet back fire from down below the truck , a couple pops & engine light then blinks. Had codes ran & it came back to
Evap canister
Evap purge valve
So I assumed when the truck bottomed out the evap can had a broken line or connection.
I checked them & they are fine. Even did a test I saw.on youtube with compressed air on evap can itself & didn't get blockage or debris. Returned connectors they are secured properly.
While climbing out from under the truck, my eyes caught something hanging, that is some sort of hose, vacuum I'm guessing, that has been broken. It's very very dirty so not even sure if it's vacuum, or when it broke. But it is supposed to be hooked to something. For the life of me I can't find where this hose goes or even another severed end. If it will return the truck to running smoothly I would like to get it fixed.
I took pictures to come here for help. The broken hose is above the transmission hanging down where it meets the drive shaft. That's up towards the front of the truck compared to where the evap canister is. I don't see any place on the canister where a missing hose.goes.
Sure need this one fixed it's the hay wagon, now the girls don't want to drive it Thanks to anyone that has any ideas.
Old Mar 5, 2024 | 12:27 AM
Post the entire trouble codes and full definitions please.
Looks like a transmission vent to me. See where it leads. Make sure it isn't blocked, but I don't think it's causing your problems.
Old Mar 6, 2024 | 9:17 AM
JoeV1973's Avatar
Old Mar 7, 2024 | 8:06 AM
I would start with cleaning the throttle body and inspecting the wires. Then smoke testing the EVAP system for leaks.
Try the troubleshooting here: https://www.obd-codes.com/p0121
https://chevroletforum.com/forum/exp...25/#post496093
Olgi
Jul 14, 2020 5:01 PM
Frank Civitano
Apr 20, 2020 4:15 PM
Hey
Aug 13, 2017 5:05 PM
VAJim
Feb 7, 2017 6:05 AM
Resendiz
Aug 8, 2015 9:09 PM
