Old Aug 10, 2015, 11:17 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior Guides
Print Wikipost
2008 Silverado Radio/Speakers issue
Old Jul 16, 2010 | 11:55 AM
crwalker2's Avatar
Default 2008 Silverado Radio/Speakers issue
I have a 2008 Silverado LT, 2WD, 5.3L. A couple days ago I got into the truck to leave and noticed the radio sounded weird. I thought it was just a problem with the XM. I checked the balance and fade and everything was set right. I moved it to the front speakers only and realized that the front door speakers weren't working. Then they started coming on and going off on their own. I also have a cruise control problem, namely it doesn't work anymore. I'm starting to wonder if I have some wiring issues. Its hard for me to believe that there should be too many issues with the radio wiring.
Does anyone have any ideas? Any help would be greatly appreciated.
Old Aug 26, 2011 | 8:54 AM
Joshc22's Avatar
I have the same problem. I can tap my brake and it will let my cruse work sometimes. Did you ever hear anything about this??
Old Aug 27, 2011 | 4:40 PM
bill64's Avatar
I have the same radio problem on 06. I don't know if it's the radio or speakers. I'm going to try new speakers,got my fingers crossed that's all it is.
Old Aug 28, 2011 | 11:34 AM
baldana's Avatar
On my 2008 Silverado, the radio works with no bass or you get the feeling that there are some speakers not working> I also turn up the volume all the way and it sounds like 25% of my Toyota. I sounds music with no bass.
I tested each speaker 1-by-1 and all works. I also turned off the "Auto-Volume" with no luck.
While driving, suddenly I get bass, the music start to sound good and the volume gets hard that I have to turn it down a lil bit.
Anyway similar occurrence...?
Old Aug 29, 2011 | 8:14 AM
Joshc22's Avatar
Yes my speakers start working randomly. It started with just my drivers side speaker and now it's both front speakers. Sometimes as soon as I get back in, after them both not working, they will be working. And sometimes they will just start working while driving. Normally the passenger side then the drivers side if at all. At which now I run the risk of being that guy driving down the road with my blinker on since the sound works through the drivers side speaker. I've tried moving wires around throughout the dash to the speakers. I tried unplugging all the connections with no changes.
Old Aug 29, 2011 | 10:26 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Have you tried to contact the dealership? They will be able to test and diagnose the vehicle and see what the problem may be. Let me know how it goes there.
Breanne
Chevrolet Customer Assistance
Old Aug 29, 2011 | 11:17 AM
OLD WRENCH's Avatar
Breanne:
They already know they can take it to a dealer and pay $100 an hour but they are trying to avoid this. Now if you could do some research and find the usual causes for this that would be helpful.
Old Sep 4, 2011 | 2:28 PM
sledheadred's Avatar
wow, im having same problem, guess no one has the answer eh?
Old Sep 4, 2011 | 3:02 PM
vtprairie03's Avatar
i have the same problem with my 08... it started about 6 months ago with the passenger speaker not working and then went to the drivers side as well. every once in awhile ill hit a bump or something and it will kick on. sounds to me like chevy needs to recall this problem......
Old Dec 23, 2011 | 5:14 PM
kdavis4998's Avatar
Default Speakers 08 3500
I had 2 working and now none. Only ones working on my 08 are the tiny ones by the windshield. Sounds like a tin can. Any ideas?
