2008 wont go over 20 mph
Likely on the money, MMJ. The ECM can likely detect a difference in the gear ratio of say a 3.42 and a 4.10 axle, so it compensates by slowing the motor down. That's gonna tear something up if the axle ratios don't match for sure.
Can you be more specific? Like is it just not shifting out of 1st, or the engine is hitting an RPM limit. You need to walk us through exactly what happens when you drive the thing.
Maybe you just knocked the speed sensor loose when you changed the rear axle.
When your driving normal in drive the truck acts likes it has a engine brake at 20mph..I tried to manually shift it and 1st gear works fine but then ur at 5k and try to shift time 2ed it just starts to rev up and slows down like its braking hard.
crwalker2
Dec 24, 2010 5:55 PM
