2011 Ticking Noise
Old Feb 8, 2024 | 9:50 AM
Abedfarha's Avatar
Default 2011 Ticking Noise
Ticking videoI was pulling into my house and I just started to hear a ticking noise, wanted to see if anyone knows what it is, i don’t know if it’s a lifter or what. I attached a video
Old Feb 8, 2024 | 3:16 PM
Sounds bad. Post your engine or VIN please.
Old Feb 8, 2024 | 3:27 PM
Abedfarha's Avatar
it’s the 5.3 V8, Car is a 2011 Silverado 1500 LT
Old Feb 8, 2024 | 3:37 PM
Pretty good chance that it is. Pop the rocker covers and see.
Old Feb 8, 2024 | 3:40 PM
Abedfarha's Avatar
Yea that’s what I’m gonna do tomorrow if I have time, also just curious, if the lifter is bad do I have replace the lifter or is there a way to clean it and just use the same one?
Old Feb 8, 2024 | 4:33 PM
depends how long it's been going on for and how bad the damage is. Stuck lifters can damage camshafts and bores, and at that point it's an engine rebuild or replacement.
At minimum the lifters should be replaced with the updated ones, and possibly the VLOM too. There's plenty of videos about it on the web.
Old Feb 15, 2024 | 9:05 AM
MLP's Avatar
MLP
Whats ur opinion on 08 1500 5.3 248kmiles with intermittent ticking? Weather seems to plays no role. Could go a day or two without ticking, sometimes only ticks at idle other times will start ticking when running 60mph, sometimes if it’s ticking at start up u can shut it off and restart then it goes away. Sometimes its a relatively suttle typical 5.3 tick other times it’s obvious something is wrong but Its so sporadic and random. Any ideas?
Old Feb 15, 2024 | 1:08 PM
Originally Posted by MLP
Any ideas?
same advice
Old Feb 19, 2024 | 11:47 AM
MLP's Avatar
MLP
same advice
ur thinking its a lifter or lifters? Surely one isnt stuck or collapsed since it comes and goes? Or is that still a possibility? Another thing I noticed is when I park uphill it doesnt seem to ever tick at start up but if i park downhill it occasionally will.. i didnt know if any of that would possibly be a sign of a weakening/failing oil pump or somethin with the pick up tube? U can also throw some sea foam in the crankcase and pretty much immediately stops the ticking but that usually only last for a few days at most
Old Feb 20, 2024 | 12:41 AM
only one way to find out
wakeboard8787
Sep 4, 2021 8:39 PM
GreaseMonkey4x4
Jun 25, 2012 10:01 AM
RFZ167Rick
Mar 6, 2012 7:53 AM
jroot
Aug 23, 2011 5:53 PM
mandyc
Jan 3, 2008 8:56 AM
