5.3 AFM replacement
Old Oct 23, 2022 | 5:48 PM
Gpetrie's Avatar
Default 5.3 AFM replacement
Can I replace my 5.3 Afm motor with non AFM 5.3 what needs to be done?
Old Oct 25, 2022 | 9:34 PM
ncsouthpaw's Avatar
My understanding is you need to have the computer programmed to turn the AFM off. Then it will run on all 8 cylinders full time. I had this done to a 2009, it did hurt the mpg but it ran better. This was after the oil rings became stuck and it started using excessive oil.
Ronnie J
Old Nov 1, 2022 | 1:03 PM
RBUser's Avatar
Did you ever get an answer to this? I have the same question, but the one response you got wasn't addressing what you'd asked.
I just received a Diablo Predator 2 programmer that is supposed to shut off the AFM/DOD, so hopefully that will help for now. As you'd asked, I'd actually like to someday replace the engine with some other small block chevy, like the 350 ci crate engines you can find out there.
Mickeyg316@gmail.com
Oct 5, 2021 12:32 PM
Hokiefan
2014 - 2018 (GMT-K2)
May 12, 2021 8:39 PM
Adventuredude
2007 - 2013 (GMT900)
Nov 12, 2018 7:52 PM
wijeeper
Apr 23, 2016 8:08 PM
Lightyning
Dec 12, 2011 9:48 AM
