Hood Open warning will not go away.
Old Mar 17, 2019 | 3:45 AM
kraft's Avatar
Default Hood Open warning will not go away.
Hood Open warning message on electronic display. Showed up first around 2 months ago but then went away. Came back about a week ago and won't go away.
Truck is a 2013 Silverado 2500HD duramax 4x4
Old Mar 17, 2019 | 7:35 AM
Look for the hood switch which should be in the hood latch assembly. You might have to replace the whole assembly. In most cases this will fix your problem.
Old Mar 26, 2021 | 6:29 AM
DMThornton's Avatar
Found on another site that the computer is looking for 2.1k ohms of resistance in order to enable the remote start. I bought a pack of 2.2k ohm resistors on Amazon for just over $5, soldered one in and it all works. Shocker! Solder in the resistor to connect the black wire and brown/green wire coming into connector prior to the latch switch (see pic). I used a few layers of shrink tubing and electrical tape to protect it from the elements and then tie-wrapped it up to keep it from flopping around. Beats replacing the whole latch assembly or waiting for the dealership to fix the problem either under warranty or for a few hundred bucks. Easy fix, good luck.
badsled
Dec 26, 2020 7:47 PM
BamBam
Jan 2, 2010 9:28 AM
zfcastle
Mar 5, 2009 7:19 PM
ez1putt
Oct 15, 2007 7:09 PM
speedy
Mar 25, 2006 8:29 PM
