TPMS issues
Old Sep 6, 2022 | 12:50 PM
rcorn1031's Avatar
Banned
Default TPMS issues
On a 2007 Silverado 1500 4x4 I have an active TPMS light . It occurred when the (RF) tire pressure went low due to a small leak . I corrected the tire pressure and drove the vehicle approx. 5 miles and light did not turn off . I connected my diagnostic tool and can find no entry for tpms sensors to read data or codes .
I did perform a tire position relearn with the tool and light remains on .
I reset tires to 45 psi because that is where I run them because my truck is not empty by any means and I run LT tires and Not P tires these tires are good for up to 80 psi each .
The Driver info center indicates all 4 tires are at my desired tire pressure and light still remains on. I have disconnected the battery completely removing power from the ECM’s and modules .
The light remains on after every self test ignition cycle .
Might anyone here have any idea(s) that I have not already tried short of a cost prohibitive visit to a dealership ?
September 17 2022
So my issue is resolved .
With the addition of a TPMS sensor wand to my scan tool inventory . I was able to resolve the issue .
With the diagnostic tool in OBD2 mode and with the tpms wand paired to the tool a relearn process was initiated and once completed this way the TPMS MIL was off .
Apparently the truck is not capable of doing this on it’s own as advertised and demonstrated in several videos . as I had already tried that procedure several times .
Also a benefit of using the tool and wand was I had no air loss from the tires and did not have to refill them .
I hope this helps others .
Last edited by rcorn1031; Sep 18, 2022 at 11:41 AM. Reason: Update : Issue resolved
Old Sep 8, 2022 | 1:05 AM
oilcanhenry's Avatar
Find a tech with a high-end scan tool, like mine. It will be gone forever.
Old Sep 8, 2022 | 3:52 PM
rcorn1031's Avatar
Banned
Default Not preferred solution
I do Not wish it be “gone forever” it exists for a reason . I only want it fixed . And I do have a high end scan tool but the TPMS items are Not in it because 07 was an option year on GM’s
NOT mandatory like 08 and after .
Thanks for the reply though even if it was not helpful or insiteful .
Old Sep 9, 2022 | 3:31 AM
You misunderstand me. What I meant was it would clear the code up now, not litterally forever. I am not clairvoyant and everyone makes a mistake, including me. I am only human, like just like you are.
Old Sep 18, 2022 | 11:43 AM
rcorn1031's Avatar
Banned
Default issue resolved
So issue is resolved . See edited original post for resolution details .
Old Sep 19, 2022 | 8:34 PM
Good work!
Ken3000
Sep 11, 2022 7:04 PM
Chuckm51
12
Jan 30, 2019 1:52 PM
srp204
Colorado
Mar 10, 2017 9:35 AM
Ron1979
Nov 22, 2016 9:07 AM
Slimj77
Avalanche
May 31, 2012 12:30 PM
