2015 Silverado 2500 HD Steering Gear Leak
Old Jun 1, 2023 | 2:01 PM
Grythus's Avatar
Default 2015 Silverado 2500 HD Steering Gear Leak
My Silverado 2500HD is leaking from the input shaft/steering column connection to the steering gear. I can't for the life of me find the seal kit part number that belongs to this truck. Everything after 2006 doesn't seem to have kits and everything after this year went electronic... This still has the hydroboost. Just looking for a seal kit... splines and pitman are still tight. Can anyone help me out?
-G
Old Jun 3, 2023 | 8:33 PM
dpieroni3's Avatar
can try contacting a dealer for a part number
Old Jun 4, 2023 | 9:34 AM
try the dealer. If they can't get it; its not serviceable...replace steering box is what they want for a repair. If you have time for the vehicle to be down...see what is in there for a seal. usually you can get pitman shafts and seals. sector shaft seal is not a common leak point.
Old Aug 31, 2023 | 1:38 AM
Zrussell's Avatar
Default Idler arm
What tools did you use to remove the idler arm. Asking because I'm about to replace the one on my truck.
Thanks
Old Aug 31, 2023 | 3:17 PM
Thanks
Nobody said anything about idler arms.
I just pried it off with a big screwdriver but you may need to use a puller.
Shaba
2014 - 2018 (GMT-K2)
Mar 26, 2022 9:50 AM
Steve Hinnergardt
Oct 9, 2017 10:04 PM
Olle61
Jan 16, 2015 1:23 AM
DaytonTD
Mar 12, 2014 11:22 AM
Peter M
Jul 23, 2011 11:23 AM
