Priming/not priming fuel pump
Old Nov 22, 2020 | 8:52 AM
Hokiefan's Avatar
Default Priming/not priming fuel pump
What would cause the fuel pump to not prime after my '17 Silverado has been sitting overnight? I've noticed that when it does not prime when I open the drivers door the truck will not start. Is this normal?
Thanks.
Old Nov 22, 2020 | 12:05 PM
Does it not start at all, or does it crank for a while before starting? It sounds like from what are saying that it loses it's prime overnight, but will start. This is because the check valve in the fuel pump is bad., If this is the case then you need to replace the fuel pump assembly or add a check valve into the fuel line.
Old Nov 22, 2020 | 7:36 PM
Hokiefan's Avatar
It won't start at all if I don't hear the fuel pump when I open the drivers door after it's been sitting for a while. Won't even turn over. Battery and alternator have both been checked and are fine. GM is telling me to pull the PEPS/HVAC fuse for 5 minutes and then plug it back in and restart until they get a computer update out early next year.
Old Dec 15, 2020 | 5:02 PM
Hokiefan's Avatar
It did it again this morning. No fuel pump priming...no humming noise...and the truck would not start. After 10 or 15 minutes I opened the drivers door and heard the fuel pump priming and the truck started.
This is making no sense to me!!!
GM Please Help!!!
XAQSHNR
K5 Blazer
Mar 29, 2020 5:16 PM
rowekmr
Jul 20, 2010 1:59 AM
LHHEMS
Dec 28, 2007 7:18 AM
Enstar
13
Jun 22, 2007 10:36 PM
