Temperature Sensor works for 2 weeks at a time
Hey. My temperature sensor will work for a couple of weeks and then will no longer read the engine temp. Result is fan running after motor is switched off.
I have replaced the sensor and the connection.
Still stops working after about 2 weeks.
The fix is to disconnect power and then reconnect. Fixes it every time but only for a while.
What could cause this? Thanks.
