6 spd or 8 spd?
Old Nov 13, 2024 | 12:56 PM
DanS's Avatar
Default 6 spd or 8 spd?
I am looking for a 2020-2022 double cab 5.3 Trail Boss, Seems some have the 6 spd some the 8 trans. Has the trans issue been worked out? Is one better than the other. Prolly only tow a 19' aluminum bass boat or my motorcycle and its trailer. Mostly hwy driving. But will do some off road. I like the trail boss because of the 2" lift and I like keeping mods like that per factory.
Seems this topic is all over the place, some love the 6 or 8 and some hate it.
Old Nov 14, 2024 | 3:36 AM
kevin spahr's Avatar
I had heard that they had problems with the 8 speed during the years you specified? I guess the 6 speed is the way to go. Not sure about the newer models?
Old Mar 21, 2025 | 9:23 PM
fingers002's Avatar
I had six speed with no problems. The "transmission" problems are not quite correct- actually. . . defective torque converters throwing "shrapnel" into transmission. Most of the problems affected 8-speed trans but 6-speeds also affected to a lesser degree. I changed trans fluid every 30,00 miles AHEAD of scheduled maintenance. I went to 103,000 miles then had a serious accident and vehicle totaled! Air bag deployed with no bodily injury. Trans models affected are 8L45 and 8L90 used across many Chevy, GMC and Cadilac models. The remedy is to switch to "Mobil 1" ATF per TSB 18-NA-355. Check it out.
ehuff19
2014 - 2018 (GMT-K2)
Aug 13, 2023 4:35 AM
Jerhed99
Apr 7, 2022 12:51 PM
subfan597
Aug 2, 2021 10:16 AM
mercracing
Mar 28, 2011 12:15 AM
white bear
Jan 22, 2011 12:35 PM
