Astro 1985-2005
Platform: M-Body
1995 chevy astro parking light problem
Old Nov 29, 2009 | 10:57 PM
jlf85's Avatar
Default 1995 chevy astro parking light problem
Hi guys,
I have a 1995 astro and I am having issues with my parking lights. They flicker and seemingly short when the switch is turned off and the key is not in the ignition, and appear to be shorting out. I tried unplugging the wiring harness to the switch to see if it was faulty and they still flickered. I also tried removing the fuse that is supposed to be for parking light and it still didn't solve the problem. I suspect I may have a wiring issue. Any thoughts? or does anyone know where I might find a wiring diagram for the lights? any info would be greatly appreciated
thanks!
Old Nov 30, 2009 | 1:59 PM
jlf85's Avatar
anyone? could it be an issue with the relay?
Old Nov 30, 2009 | 9:54 PM
ihatemybike's Avatar
I really don't know. Does it happen all the time, just when the vehicle is in motion, parking lights only or headlights too?
Old Dec 1, 2009 | 4:05 PM
jlf85's Avatar
it would seem it happens only when the vehicle is parked I think, but I'm not sure. It is only the parking lights (the amber ones on the front). It really seems like a wire is shorting as they flash for a brief second then go out, in an irregular pattern. I just cant wrap my mind around why, after I took out the fuse, they were still flickering. It keeps killing the battery and I really need to figure it out..
Old Dec 2, 2009 | 6:24 AM
Sound like you have a bad wire somewhere. Since they are getting power with the fuse removed, pull other fuses one at a time till they lose their power source. This will narrow down which wires need to be inspected/repaired.
kaptain howdie
Dec 16, 2014 8:20 PM
Big Allan
Aug 1, 2013 4:50 AM
mrrish2010
Astro
Nov 7, 2010 9:56 PM
Chevypowerbaby
Jan 30, 2009 4:19 PM
