Astro 1985-2005
Platform: M-Body
Can't identify a sensor on engine block that is cracked and needs replacement
Old May 19, 2017 | 8:59 PM
AstroBoy94's Avatar
Default Can't identify a sensor on engine block that is cracked and needs replacement
If you are inside the van, it is on the left side of the engine block, above the spark plugs, and is blue. The harness for this sensor goes over the engine, then back down to the back by the distributor, combining with several other harnesses. I have a photo o the sensor, but I'm not sure how to post it n this forum.
Old Sep 22, 2017 | 9:42 PM
George A Hartman's Avatar
I don't know the year or the engine size of your van but, if it is like mine, a 1994 with a 4.3 V6 maybe I can help you. It could be one of 2 sensors. One is a coolant temperature sensor with 2 leads going to the connector or a knock sensor (rear) with a single wire to connector. I hope this helps.
Old Jan 23, 2018 | 8:55 PM
69roadrunner's Avatar
Coolant temperature sensor. Single wire. Goes up and over the valve cover.
Old Jan 26, 2020 | 5:08 AM
delshan's Avatar
There's a map sensor just under the top hose on the bulkhead, a bit difficult to get to. other sensors on the air intake tube can be cleaned with an air flow sensor cleaner spray, available on Ebay or Amazon. videos on YouTube.
Old Jun 24, 2020 | 8:00 AM
delshan's Avatar
Default MAP sensor
Located under top hose near bulkhead, bit difficult to get at, but whilst you're about it and have the hose off, I may suggest you clean the air sensor.
AstroBoy94
May 20, 2017 8:41 PM
Mitchh
Aug 26, 2013 9:18 PM
ekimw2500hd
Mar 7, 2013 9:30 PM
randyrt
Sep 1, 2009 9:30 AM
290
Jul 23, 2009 8:19 AM
