Chevrolet Avalanche
Platform: GMT 805 & 900
05 Avalanche steering column electric issues
Old Nov 5, 2023 | 7:39 PM
ProfessorDave's Avatar
Default 05 Avalanche steering column electric issues
Hey guys, when I turn my blinker both blinkers flash the selected blinker flashes brighter (Does this for both left and right selections). Horn doesnt work unless key is out of the ignition when I press the horn both blinker dimly light up on dash, same with turning on bights and fog lights. Air bag light is on also.
So far I redid the Left side frame grounds, made sure the engine to fire wall ground is good. Can any modules cause this? I plan to check other grounds also I just found a diagram for a 02 which I assume should be the same.
The truck came from the north so its rusty. Honestly was a bad buy didnt notice how bad the rust was until I purchased it, but it was intended to be a work truck so its all good.
The truck is a 2005 Avalanche Z95 4x4
Old May 24, 2025 | 5:23 PM
travisdaerr's Avatar
I assume you got this resolved, I just installed a new blinker/multifunction switch with help from Youtube, cost about $30 and took about 30 minutes. Let me know if you didn't get it figured out.
ramccombs
Avalanche
Mar 28, 2018 8:27 AM
worldofhurts
Oct 11, 2014 11:10 AM
wmentzer
Sep 4, 2010 3:22 PM
bullet62
Nov 26, 2009 11:09 AM
wile7e
Aug 1, 2008 5:00 PM
