Chevrolet Avalanche
Platform: GMT 805 & 900
08 Avalanche cruise control intermittent
Old Jan 14, 2015 | 10:47 AM
Axle314's Avatar
Default 08 Avalanche cruise control intermittent
Cruise will engage about 50% of the time when I push the set button and once or twice while on cruise it stopped and green indicator was gone from dash.?????
Old Jan 15, 2015 | 7:57 AM
Axle314's Avatar
You mean to tell me no one has had cruise issues in an avalanche ? If so and you had repaired what was the common issue here. Thanks
Old Feb 2, 2015 | 3:16 PM
z28summit's Avatar
Your brake switch is starting to go. If it happens again, try making an braking application. Should work after that. If it gets bad, its a $30 part GM. Its located straight up above the brake pedal under the dash
Old Feb 3, 2015 | 6:38 PM
Axle314's Avatar
Thanks summit !
Old Jun 18, 2015 | 12:12 PM
jezitzma's Avatar
Mine went out, bought one off of amazon and it took maybe 30 minutes to replace. Found a YouTube video before I started. It helped a lot. Works great.
crosskeystv
Nov 17, 2022 6:38 AM
Relayer56
Avalanche
18
Mar 29, 2021 10:43 AM
e-roc559
Dec 13, 2013 11:58 PM
asgraber
Avalanche
Aug 11, 2010 9:02 AM
kbridge234
Sep 4, 2008 10:03 AM
