Chevrolet Avalanche
Platform: GMT 805 & 900
2002 Chevy Avalanche 1500 brake issues
Old Sep 17, 2023 | 4:10 PM
JRKnight's Avatar
Default 2002 Chevy Avalanche 1500 brake issues
Hi I have a 2002 Chevy Avalanche 1500 and I am completely stumped with this. I have changed the brake pads the master cylinder the brake booster and I still don't have brakes they are not working and anyway shape or form. I've tried bleeding them several times and I'm just completely baffled on why they're not working any ideal suggestions or thoughts only a subject would be really helpful I need my truck back. Thank you all in advance.
Old Sep 23, 2023 | 8:34 AM
spyncycle's Avatar
Might need to reset the brake proportioning valve.
Old Sep 23, 2023 | 9:51 AM
Welcome from Florida. Did you bench bleed the master cylinder before installation?
Old Nov 30, 2023 | 4:34 PM
marimelinc@comcast.net's Avatar
Default I'm in the same boat .and at a loss .
So I have the exact thing happening replaced pads ,rotors, hoses, abs ,modal, booster , and Master cylinder . I have bled many times as well as abs bleed , with Snap On scanner . So my question is have you figured it out , cause I'm at a loss . Thanks In Advance For Any ........Help !!!
Old Dec 12, 2023 | 2:42 PM
So I swapped the truck to Hydro boost out of an Escalade , AND.........YES!!!!! it has brakes . Everything else is a BIG waste of time next for more Maybe the 14 inch front rotors and calipers off a 07 -11 Tahoe Burban etc .
All the stuff bolts up minimal mods .
Old Dec 5, 2024 | 5:15 PM
McWink81's Avatar
Default 2002 Chevy Avalanche brake issues
I had the same problem. Check your soft brake lines and then your EBCM. It's under your truck below driver's seat. Good luck
wil2007
Apr 15, 2023 12:39 AM
Silent Screamer
Avalanche
Oct 28, 2021 7:10 PM
Rooty
Avalanche
Jan 16, 2018 12:29 PM
jrweld20
Dec 27, 2009 10:18 PM
