Chevrolet Avalanche
Platform: GMT 805 & 900
Stabilitrak (3rd time)
Old Apr 16, 2017 | 8:36 PM
Creekside's Avatar
Default Stabilitrak (3rd time)
2008 Avalanche LTZ 89500 miles.
Stabilitrak for third time since 2013. Rough riding and serviice traction.
Vehicle repaired by Chevy dealer in Kalispell, Montana in June 2013.
Service stabilitrac, replace valve cover,replace all spark plugs and wires, clean injectors. With oil change over $900
Vehicle repaired by Dealer in Puyallup, WA in Aug 2015. Same symptoms.
Replaced all spark plugs, replaced left valve cover gasket . (over $900)
Old Apr 16, 2017 | 9:23 PM
i assume the engine is misfiring and burning oil
Old Apr 17, 2017 | 8:15 AM
Creekside's Avatar
Trying to figure out how to reply. Yes rough ride and burning oil
Old Apr 18, 2017 | 8:19 AM
the plugs are fouled from oil consumption and the repair was done 2x and still now change?
did they remove the oil pan and install the shield over the afm relief valve in the oil pan?
Old Apr 19, 2017 | 7:53 AM
Creekside's Avatar
Vehicle is being repaired as we speak (Apr 18 all day and still at the dealer on April 19). Yes, they are installing the shield this time. Not sure why this was not done in 2013 or 2015. Thanks for the advice and input
Old Apr 19, 2017 | 1:35 PM
they need to clean the oil control rings...that is part of the procedure also.
Old Apr 20, 2017 | 7:58 AM
Creekside's Avatar
yes they did clean the rings. removed oil pan-replaced gasket, add deflector. knock on wood -- vehicle runs like new-- we shall see
Old Apr 20, 2017 | 8:27 AM
check your oil level at each refueling untill the first oil change. use the same routine at each check...engine off for 10 minutes to let the oil drain down.
Old Apr 21, 2017 | 8:05 AM
Creekside's Avatar
will do. Thanks for your suggestions.
Old Jun 19, 2017 | 5:55 PM
Creekside's Avatar
After almost a couple of months--oil is fine, but now check engine light is on. Checked gas cap--engine light still on. Will take the 2008 Avalanche to the dealer in the next day ot two
