1990 Lumina van blows fuel pump fuse
I have a 90 Chevy Lumina van with a 3.1 motor that blows the fuel pump fuse when I put the vehicle in reverse. I can put it in drive and it does not blow the fuse. Runs fine in park also. Any suggestions would be very helpful thanks
You might have bad wires somewhere, or at some point, the wires got crossed.
Maybe try removing the reverse light bulbs and see if it still happens? If so, then someone stuck your reverse power off the wrong fuze, or maybe you have the incorrect fuze...
if that is not the case and it still blows the fuze, then somewhere wires are rubbing and grounding out...
2cool4air
November 17th, 2012 3:52 AM
juan10
September 25th, 2009 11:29 PM
ratnin57
August 18th, 2007 8:04 PM
