Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
1990 Lumina van blows fuel pump fuse
Old Oct 4, 2012 | 6:13 PM
bslayter's Avatar
Default 1990 Lumina van blows fuel pump fuse
I have a 90 Chevy Lumina van with a 3.1 motor that blows the fuel pump fuse when I put the vehicle in reverse. I can put it in drive and it does not blow the fuse. Runs fine in park also. Any suggestions would be very helpful thanks
Old Oct 27, 2012 | 3:03 PM
GHOSTOWLGRID's Avatar
You might have bad wires somewhere, or at some point, the wires got crossed.
Maybe try removing the reverse light bulbs and see if it still happens? If so, then someone stuck your reverse power off the wrong fuze, or maybe you have the incorrect fuze...
if that is not the case and it still blows the fuze, then somewhere wires are rubbing and grounding out...
Old Oct 27, 2012 | 3:05 PM
kevinkpk's Avatar
More than likley it is in the column. Wire to pump hot in on, ok in drive, but blows fuse in reverse. I'd look at the wiring around the shifter
2cool4air
Nov 17, 2012 3:52 AM
Eric's S-10
Jan 25, 2012 7:24 PM
juan10
Sep 25, 2009 11:29 PM
ratnin57
Aug 18, 2007 8:04 PM
DAWTSF
Oct 3, 2006 12:26 PM
