Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
Coolant leak 1995 Lumina
Old Aug 21, 2012 | 10:44 AM
RolloTomassi's Avatar
Default Coolant leak 1995 Lumina
I've got a coolant leak near the timing chain on my 1995 Chevy Lumina. If I take this to a repair shop, what will they do? If I take the DIY route, what kind of coolant repair products can I use to fix it myself?
Bear in mind, I do not have a lot of money and I'm a novice. I can spend maybe $30-40 to fix this car on my own before taking it to a professional, thanks
Old Aug 21, 2012 | 12:00 PM
If it helps, I changed the water pump, lower and upper radiator hoses and radiator cap within the past 12 months
Old Aug 21, 2012 | 5:00 PM
bump!
Old Oct 14, 2012 | 5:54 PM
92chevycorsicalt's Avatar
Is it coming from around the water pump?
Old Oct 15, 2012 | 8:14 AM
The leak has actually stopped for now, weird lol
Old Oct 17, 2012 | 1:09 AM
harry5's Avatar
Banned
I had just replace the radiator but it again causing some problems.
Old Dec 23, 2012 | 2:32 PM
GHOSTOWLGRID's Avatar
Possible leaking points:
Timing cover front or rear sides.
Lower intake manifold gasket which is right above timing cover.
Water pump which is on the timing cover housing.
Or one of the hoses above the water pump.
Old Jan 14, 2017 | 11:34 PM
MCRC007's Avatar
Could be as easy as this little hose right here
Old Jul 29, 2017 | 9:50 AM
shawnabecker's Avatar
bump!
dlaroche
Oct 29, 2014 7:17 PM
Warbucks79
11
Sep 11, 2013 2:10 AM
Warbucks79
Apr 16, 2013 11:24 PM
Jessicalynn927
Jul 1, 2010 6:34 PM
95wt
May 30, 2008 3:07 PM
