Beretta, Corsica, & pre-1995 Lumina Among this grouping, these three cars, while being similar to each other, offered something for everyone, from a sports coupe to a roomy sedan.
Platform: L-Body
Temperature gauge moves around
Old Mar 9, 2013 | 11:12 PM
Blue92's Avatar
Default Temperature gauge moves around
I just bought a 1992 Corsica 3.1 with 54k original miles. It runs great, but I've noticed that the temp gauge moves around while I'm driving. It kind of "twitches" around the middle of the acceptable range. I've checked the coolent level-it's fine. Is this normal for these cars?
Old Mar 21, 2013 | 1:59 AM
Valence_Flame's Avatar
I think it might be, I just bought a 95 Beretta and it does the same thing, I'm going to get it checked out anyway and hopefully get it to read accurately
Old Mar 23, 2013 | 11:59 AM
Blue92's Avatar
I took it to my mechanic the other day. He couldn't find anything wrong. Said just to keep an eye on it and pull over if it goes over into the "red zone". I'd say, drive it like you normally would.
Old Jun 15, 2013 | 12:40 PM
GHOSTOWLGRID's Avatar
nope, the sensor is going bad slowly...
Unless there is a lose connection somewhere, or the gauge is broke...
Old Aug 15, 2013 | 4:16 PM
Crazy Diamond's Avatar
My advise is to treat it as normal unless it goes into the danger zone. I have a buddy that have this happening on his 1995 Cavalier.
Old Aug 16, 2013 | 11:38 AM
The only problem with this is if the engine gets to hot and as the sensor is failing and it does not read higher like it should, thus causing the engine fans to not come on. which can cause it to over heat and that is bad.
Either way, its better to be safe than sorry and just replace the sensor.
Or at least have it checked if the sensor is good and to test for faulty wiring.
Chevrolet Forum News
Apr 5, 2013 3:08 PM
stillmuddin82
Mar 31, 2013 1:40 PM
veryscary
Jun 30, 2011 6:42 PM
haidangwa
May 3, 2011 2:19 PM
