Blazer Combining style with comfort, this all-new, sporty SUV is the epitome of adventure.
Chevrolet Blazer
Platform: C1XX
Can't get crank position sensor to seat in block
Old Dec 11, 2024 | 3:24 PM
Jimsa's Avatar
Default Can't get crank position sensor to seat in block
Hi everyone. I'm working on my sister's 2007 Blazer 4.2. Her engine light came on and threw a p335 code. Removed sensor, went to install new sensor and couldn't get it to seat in the block. Jumped on YouTube and found a video by a mechanic working in his shop (as opposed to a backyard mechanic) and he said it'll go in most of the way, then use the hold down bolt and that should seat it. We'll, I broke the tab that holds the bolt. I picked up another sensor and don't want to break another one. Anyone run into this before? Any suggestions? I tried a search but only got general sensor posts and posts about seats. Thank you very much
Old Dec 12, 2024 | 11:51 AM
Oldcat's Avatar
Is there any piece of the old sensor broken off and is still in the block? If not make sure you lube the sensor o-ring with silicone grease or vaseline. That will help it slide in easier.
Old Dec 12, 2024 | 3:19 PM
Jimsa's Avatar
Default Solved
thanks Oldcat. I managed to get it in this morning. Slid a 15/16" socket with extension over it until it rested on the shoulder of the sensor. Then put a length of rebar into the extension from the wheel we'll and gently tapped it in with a hammer. A little awkward because the steering column was in the way but got it in.
Yogi
Jan 3, 2014 6:37 PM
d0n
Sep 11, 2013 12:00 AM
secorbust
Feb 25, 2013 3:41 PM
birdie
Mar 16, 2010 2:21 PM
2004TahoeZ71
Apr 1, 2009 1:49 PM
