2016 Camaro
Platform: F-Body & Zeta.
Problems with my RS
Old Jul 14, 2011 | 12:33 PM
Thirdgen_Girl's Avatar
Default Problems with my RS
I have a 92 RS that is giving me problems. The car was running great but now I am having issues getting it to start and stay running. The car will start but it sounds like it wants to die and then does in fact die out. The first time this happened, the car was running on the warm side. It started then died and it wouldn't turn over again. It drained the battery. Once I jumped the car it started again. I took my battery to get it tested and they told me it was fine, with a 100% charge. So I put the battery back in and the car ran fine for awhile. Then I drove it to the store but when I started it to leave it started, idled rough and then died. After letting it sit for a few minutes it started up again and I drove it home. Someone told me it might be the starter but it seemed more like an injector issue or sensor problem. I didn't hear any ticking from the starter. Could you guys please give me some suggestions where I should start the process of fixing this issue?
Thanks
Old Jul 14, 2011 | 1:34 PM
Chuzz's Avatar
Did this happen after getting gas somewhere? If so, you may have water in the gas. It could also be a defective coolant temp sensor, mass air flow sensor or 02 sensor. If you're close to an Autozone or Advance Auto Parts, take it there and have them read the codes and see what they tell you.
Old Jul 14, 2011 | 4:33 PM
No, I have not purchased gas recently. I am close to both of those parts stores so I will see what they say. Thank you.
Old Jul 15, 2011 | 7:16 PM
Chuzz's Avatar
Post back and let us know if they were any help.
Old Jul 16, 2011 | 2:26 AM
They couldn't tell me anything because the car was not spitting any codes out. The service light was not on and they found nothing wrong with it. You know how it goes...its like going to the doctor...the problem never presents iteself when you actually need it to. I have driven the car a few places today and didn't have an issue getting it to start after shutting it off so I have no clue at this point what was going on.
Mom2ThreeACG
Traverse
Mar 12, 2018 6:20 PM
wayne77&Trish
Sonic (Aveo)
Jun 9, 2016 12:54 AM
mwehrste
Dec 29, 2014 11:19 AM
GrayHeadedMule
Jul 9, 2013 10:16 PM
Big C
Sep 2, 2011 4:39 PM
