Platform: J-body
1993 cavalier rough running problem
Old Mar 13, 2008 | 12:38 PM
hammercr500's Avatar
Default 1993 cavalier rough running problem
I have a 1993 cavaleir 2.2L The problem is it will be running fine till you get ready to stop and you can feel a change in the way it is idleing . It startes to vibrate and shake and wants to stall. It will start back up again, but when it is put into drive or reverse it quits running. Some people have told me it could be the electronic ignition control module.Is thereany member that might have some insight as to what the problem could be ?
Old Mar 28, 2008 | 9:54 PM
kizzelwhix's Avatar
Default RE: 1993 cavalier rough running problem
I had a similar issue with my '90 cav, but only when it was raining or damp out
is this all the time or only when there's high humidity?
macmommy
Apr 22, 2020 1:23 PM
luminatorr
Nov 17, 2014 6:04 AM
bms
Apr 8, 2010 2:29 PM
kb9mnm
May 24, 2009 8:56 PM
Jro
Oct 14, 2007 2:16 AM
