Platform: J-body
2001 Cav standard 2.2L cranks but will not start.
Old Jan 21, 2011 | 6:50 PM
KunoCorp's Avatar
Default 2001 Cav standard 2.2L cranks but will not start.
Hello everyone, this is my first post on this forum. My Cav will crank forever and not start. i have done a bunch of tests and have narrowed the problem to a fuel issue. I spray starter fluid in the engine and it started and died. I am new to the car repair thing, but I am very adapt with machines so I'm pretty sure once the problem is identified, I can take care of it. It started when my battery completely died and I installed a replacement, Please help me figure this out, thank you.
Old Jan 22, 2011 | 7:49 PM
2wd-K5's Avatar
do you hear the whine from the fuel pump when you turn the ignition on? if not it is a fuel pump issue, most commonly you replace the fuel pump, but sometimes it is a relay, so check the fuel pump relay first
Old Jan 23, 2011 | 8:20 PM
KunoCorp's Avatar
I actually do hear a hum or buzz when I turn the car on. Might it be a fuel filter problem?
Old Jan 24, 2011 | 2:19 PM
2wd-K5's Avatar
could be, if u havent changed it before, i would sugesst doing so
92spi
Mar 7, 2015 3:59 PM
Jbradleyjr02
Jan 8, 2015 11:17 AM
bluedrew5091
Jun 25, 2013 12:00 PM
likitysplit
Feb 3, 2013 9:14 AM
hellspawn4001
K5 Blazer
Feb 14, 2010 5:37 PM
