Platform: J-body
2004 Cavalier cranks but no start
Old Jan 21, 2023 | 5:55 PM
  #11
97partspuzzle's Avatar
Originally Posted by ryan12345
My 2004 cavalier almost didn’t start today. It cranked over and over and over but didn’t want to start. It’s never done that before. It finally started on the third try…… is this a common problem with this model?
what scanner are you using? Cheap scanners will only point you in the general direction, wasting time and money breaking out the parts cannon hoping you get it. Just because you have fuel in the rail does not mean pressure is high enough to get fuel through injectors. Sounds like relay works, check connector at fuel pump common on 97-2003 the connector car side can get hot and melt plastic resulting in intermitant fuel supply or no supply, gonna say pump is toast. Have a friend crank while banging on tank bottom, pump motor MUST be energized to see if brushes make contact w armature. 26 years is a loooong time for a pump. Hope this helps
bholaday
Apr 2, 2021 5:51 PM
loagiebear
Mar 6, 2013 12:34 PM
rl1997
Sep 7, 2009 3:14 PM
rlhbluebird
Nov 23, 2007 4:02 PM
Rca1965
Jul 2, 2007 7:55 PM
